Stock gyro? Set the DS switch on the side of the gyro to DS position. The gain is set through the TX, remote gain control, depends on what TX/RX you are using. DX6i there are two setting in the Gyro menu, position 0 set to 65 and position 1 set to 30, this gives you rate mode in position 1 (down) and HH in position 0 (up), do your tail setup for no drift with no trim or subtrim, in RATE mode but adjusting the control rod length to achive no drift. Now go to HH mode, position 0 (up) and increase the gain in the TX untill the tail wags then back it off 5%.
