OK,
So I'm working on the blade 400 after the crash. I've worked on the rotor head and there was one thing that I identified. The 'shims' that are referred to... they're the really skinny washers, correct? I could only find 3 when I took the head apart though...
The recommendation is 2 for 'soft' 3D and 4 for 'hard' 3D, so if I'm just hovering will I be OK with one each side... until I can buy some more?
I've rebuilt the head with a new feathering shaft, ready to go back on, so I've made some progress!
Now... the main questions...
I can't undo the flybar cradle screws, so any tips? They're the ones on the ends of the silver shafts...
I'm using the small 'philips' type screwdriver I got with my CX3, which seems to fit but they won't budge!!! Any tips?
Also, it would help if I could remove the flybar paddles, but I'm not sure what size the screws heads are. I've tried 1.5mm and it's too small, but 2mm is too big, so are these imperial?
Erm... help?!!!
Erm... help?!!!
