low and high
  • low and high
    hi chaps, how do i get a level swash at low and high stick? its level at mid but it seems about a half a mil to a mil out at low and high, ive got hitec sevos on all three
    cheers jon
    blade 400 3d, gy401, hsg-5084mg tail servo, hs-65hb
    gaui 550 hurricane
    phoenix
    dx6i
    You use end point adjustments in the Tx to tell the servo that stops short (or goes too far) to go a bit further (or a bit less).
    | 3D Championship
      ive got i level at mid then low but high is out by a a mil what am i doing wrong?
      gaui 550 hurricane
      phoenix
      dx6i
        As Rob says above use endpoint controls or travel adjust to either extend or inhibit the movement of the servo for the one that is out. Make sure that the pitch curve you have is 0-100% and possibly lift the pitch value in the swash mix to give you as much travel as possible on the swash
          Are you servo arms all horizontal at mid stick?
            You could also try to adjust the cyclic servo to swash pushrods, either make them longer or shorter to make your swash level.
            ~JASON~
            HELI 1 : TREX 450 SE GF
            HELI 2 : PICOOZ HUGHES 500MD
            HELI 3: WALKERA 1#A
            HELI 4: WALKERA CB100
            SIM : AEROFLY PRO DELUXE
              I posted my answer assuming that mechanically at mid-stick, everything is horizontal (as it needs to be...).
              If the swashplate is level at mid-stick, you can't then adjust the rods to help level it top and bottom as that will affect the mid-stick "level" also.
              ATV, Travel Adjust, End Points - all the same thing - are what you need to adjust
              | 3D Championship
                cheers fellas, started from scratch and used all your helpfull advice all seems pretty much in sync, and hovers fine from floor to about 7 feet, gonna have a fly at work tomorrow and give it a good workout
                cheers again
                jon
                gaui 550 hurricane
                phoenix
                dx6i
