Not the same as the other post tonight, and could really do with some help.
Have a look at the video and see if you can work it out for me.
All trims are zeroed (or centred if you like) and when left the arm moves all the way to the right, then when I move it all the way to the left and release it slowly drifts back to the right.
When I get a good head speed up the tail whips round until I counter it with a lot of trim or loads of stick.
Any help or setup ideas would be great.
[ame]http://uk.youtube.com/watch?v=M1gg3_aKeGo[/ame]
No offence but have you crashed it at all, I had a similar problem with mine and found the tail blade shaft was bent. I'm not sure that the creeping across isn't normal as mine does the same but as I say I did find the shaft was bent.
