300x repair advice.
  • 300x repair advice.
    Need help please. Crashed my 300x, was flying nice out of the box. Bad to chane the main grips and main frame. Disconnected servos and changed over to new frame. All adjustments as before no change but a heavy roll to right on take off. Servo looks level. Tried the A swash center adjustment but of no help. Do I need to recenter swash servos by using step G..?? Help will be appreciated. Should I send to HH for setup..?
    Regards.
    I would. You may have put the servo to swash links on the wrong side. Don't know how obvious it is... scratch that, it would be very obvious as one is longer than the other. You probably need to redo the set up. It takes a while to do the first time as you are learning but a youtube video really helps and carefully following the manual.
    Vikki.
      Thanks vikki, will recheck, recenter servos and try it out.
      Thankyou & regards.
