Blade 300x upgrades
  • Blade 300x upgrades
    Hi, I have owned a 300x for a few years, it's mainly standard except canopy and carbon rotors... can anyone advise me on good upgrade spares, I've also seen Micro heli are doing a performance kit, had anyone any experience of this?
    James
    I have never had a 300x , I have 4 oxy3's which I believe are about the same size , having upgraded many blade helis Over the years I only upgrade the bits on the heli
    that are week and keep breaking , I find that so called upgrades quite often don't make the heli fly better , in fact I've had upgrades that make the heli fly worse so I don't change out unless there is a problem , hope this helps Kenny d
    Goblin , 380 Carbon
    Oxy 4 - 360
    Oxy 4 - 325
    Oxy 3 - 250 , 3s
    Oxy 3 - 250 , 4s
    Oxy 3 - 280 , 3s
    Oxy 2 - 190
    Oxy 2 - 210
    Spektrum DX9
    Revolectrix PL6 & PL8
      The 300X is quite old these days - and EOL'ed by Blade many years ago. They produced a new version - the 300CFX which was significantly different using a carbon-fibre body.
      As fas as upgrades go for the original 300X - I believe the Lynx strengthening kit was the only "must have" mod as it provided much stronger rigidity around the main shaft.
      Beyond that though - metal gear servos are an option. But if I'm honest, I wouldn't plough much money into it if I were you. You'd be better off looking at something like the Oxy3. Or the newer Blade models (270CFX being the latest "300X replacement").
      Links:
      (300X frame plate stiffener) https://www.lynxheli.com/product_inf...ducts_id=22483
      (270CFX - ie. latest "300X") E-Flite Blade 270 CFX BnF Basic Combo BLH4850
        Thanks guys will look into these your points are valid...��
          Links were very helpful, thanks, I take it there's no point in cnc machined head, tail etc... Will consider oxy as well thanks
