Trim flight and binding.
  • Trim flight and binding.
    Hi all, I've changed the gears on the elevator servo. Should I do a trim flight? Also done the mod where I've split the arm. Hopefully this will look after the silly plastic gears.
    WaveyDavey was generous enough to give my boy Joe his DX6i which I've set up to the helicopter assuming with no problems as I've not had chance to test outsidedue tto the winds. I was looking at how much the servos move in the different modes with the DX6i, then decided to bind the LP6DSM to compare before letting Joe loose with it. Although I had no problem binding the DX6i, I unable to bind the LP6DSM. Followed the instruction manual, but doesn't seem to take the original TX.
    Any ideas? Thanks
    Vinnie
    Yep! Always do a trim flight after you do anything with the servos. Also make sure they are level.
    200SRX; Gaui X3 (Spirit, HW)
