where have i gone wrong?
  • where have i gone wrong?
    Hi Guys,
    I have just fitted the lynx heli main grips and tail grips to my 130x, and now the heli just spins out of control on spool up....where have i gone wrong?
    Blade MCX2
    Blade 130x
    Blade 450 3D
    T-REX 550E
    Didn't you put the tail grips acidentally wrong way round? ie. leading edge controll instead of trailing edge?
    Compass 7HV, Beastx
    T-rex 600 EFL Pro
    , BeastX.
    ElyQ 50 Comp XE, BeastX.
    T-rex 450 Pro DFC, MSH Brain.
    Blade 130X stock.
    550 quad, Multiwii fc.
    Aurora9, DX6i, 6EX, FF8.
      Hi Franky!
      Matt,
      As well as what Franky said, check the tail gears are not stripped or cracked (try holding the head and using MODERATE pressure to turn the tail and see if it slips)
      Lastly with the TX and heli powered up (TH ON!) loosen the tail servo screws and move it up or down the boom until the tail blades are at 0 degrees. This is what finally stopped my constant piro, I could barely believe it but it worked!
      D
        Ok Guys, thanks for the tips. So heli was working fine Thursday night, last night i changed the main grips and test hovered it...all fine.....then i fitted the tail grips and it would only piro......i have checked everything is the right way round and the tail gears do not appear to be stripped or cracked, however i have noticed that the tail does not move evenly each way
        Blade MCX2
        Blade 130x
        Blade 450 3D
        T-REX 550E
          dont know the 130x but I would disconnect the tail push rod make sure the tail linkage is free and not stiff or binding. then make sure the tail servo is moving freely and not binding also may have blades on right but if you have swapped the tail arms around you will have affectively reversed the tail so it will piro.
          Stuart
            sorted...i had put the tail together the wrong way round and somehow i had managed to reverse the pitch!!! Don't work on heli's whilst drinking wine!!! Thanks for the tips guys
            Blade MCX2
            Blade 130x
            Blade 450 3D
            T-REX 550E
              We've all been there lets just say my soldering isn't my forte - lol
              Stuart
                yep i need lots more practice at that too!!
                Blade MCX2
                Blade 130x
                Blade 450 3D
                T-REX 550E
