maiden flight glitch on 130x
  • maiden flight glitch on 130x
    Was so impressed with my new mcpx bl and having lots of fun down park with it, i bought a 130x as well to really get some stick time in.I set up everthing to manual and took down to park tonight,popped it into hover and everthing good flicked into idle up and was great really locked in,then it just lost power and dropped,it was not very high and did no damage as landed on skids.It was getting dark so just went home and took blades of and span up on bench and everthing seemed fine,even loaded head witha little thumb pressure to see if anything was sliping wether it was just a glitch not sure will have a go tommrow night with more time,just wondered if anyone has had a similar experience
    Not the main gear slipped down then?
    i have had that happen. Also just the same issue with the odd dodgy battery.
      Ok thanks i have some turnigy nano techs arriving tommrow so will head out to park with them and see what happens,the main gear is def nice and tight to top not slipped down at all.The main gear seems quite slack on motor pinion but not slipping
        Mine was loose but not stripping and it flew like a dream so that sounds ok..
        have fun tomorrow.
