really loving this heli at the mo, but just wondering if any of you are having to make corrections with aileron when for instance in a backwards loop, i have to put in quite a bit of left cyclic to keep the heli straight from the top of the loop to the bottom. its not really a problem, but i was under the impression a flybarless system will make the heli track straight. i havent played with the gain on the cyclic only the tail, (using a ds35).
making corrections
backward loop on mine follows fair track, not perfect, but acceptable, only minor adjustments throughout the loop
are you sure you are not "pulling it" ?Current Heli's, Align Trex 550, Blade MCPx BL, Blade 130x, Blade 450x, JR DSX9
i would not bother with trim levers on this heli, its better to trim it by adjusting the linkage rods to the swash first, then if you have to, fine tune with a click or two of subtrimCurrent Heli's, Align Trex 550, Blade MCPx BL, Blade 130x, Blade 450x, JR DSX9
