Nano CPX to 130X
  • Nano CPX to 130X
    I just thought i would post on here, as i have just started with a 130x after learning a few basics on the ncpx. All i can say is why so people not suggest getting one of these to learn with, it is sooo muxh more docile than the ncpx, i used standard settings from the manual for both. Can hovver, both normal and a little inverted, now moving on to circles, which is proving more tricky!!
    Anyways, anyone thinking of getting a 130x, gor for it, very easy and stable to learn with.
    Beam E4
    Trex 250
    MCPX
    120 SR
    Night Vapor
    Sukhoi su-26xp
    Oh the 130x is great to learn with, just not very friendly in the house and not as robust as the smaller heli's
    T-REX 250 DFC: Hyperion HS2206-3900 / YEP18A / Mini K-Bar
    T-REX 550 DFC Pro:
    AR7200BX BeastX - Soon to be... Spirit FBL / CC Phoenix Edge 100 / CC Bec Pro / Optipower Ultraguard
    DX8: Turnigy 4000mah Lipo
    Pheonix v5.
      Blimey wouldnt fly iy inside, i would wreck the place!
      The nxpx does have amazing bouncability, thats for sure, especially as i have uprated skids to ones from the states, which i think may be indestructable!
      Beam E4
      Trex 250
      MCPX
      120 SR
      Night Vapor
      Sukhoi su-26xp
        As others have said, the 130X is a great CP heli to learn on but it is too big for most normal houses unless you are already a whizz. The Nano is small enough to get some very useful learning done in your living room without endangering the furniture too much... cover up that LED TV though!
        MCPX
        Planks - WOT 4 Foam E
          130x best garden heli!
            Nano CPX to 130X
            I am also thinking of moving from nano to the 130x so I can practise inside (gymnasium hall) and in my garden. Does it cope outside well?? After that I am planning to go to the 450x once I can fly the 130 well.
              It is only light so it won't handle as strong a wind as say a 450 but it is better than most micros and I can say from personal experience it is better than the MCPX V2.
              MCPX
                Copes outside in the wind brilliantly. Just much more stable and less twitchy than the nano.
                As with this hobby, i am now after a 450x, so have a very lightly uses 130x for sale with an additional nano tech lipo and spare white landing gear, could be a cheaper option for you ;-)
                Beam E4
                Trex 250
                MCPX
                120 SR
                Night Vapor
                Sukhoi su-26xp
                  130x handles really well in light wind conditions. Much better than ncpx or mcpx. Perfect for the gym hall
                    Nano CPX to 130X
                    Cool cheers. On a separate note. If I move on to 450x after will a dx6i still be ok to use?
                      Yes dx6i is perectly fine for 450x
                        This little darling handles the wind really well with 100% flat throttle line, you do all the maneuvers with the wind then go back into the wind & start again.
                        • Flickr Through My Pictures.
                          Nano CPX to 130X
                          Cheers mate
                          Looks like I have my shopping list sorted
                            Nano CPX to 130X
                            Thanks for the info. Just nice to hear the heli can cope outside.
                              The 130x is pretty good outside, it's the only place i fly it
                              T-REX 550 DFC Pro:
                              Pheonix v5.
