130 blowouts
  • 130 blowouts
    Hi can anyone give me the answer to why the 130 has decided to start blowing out on me. Not flying 3d, gain set to -8 as I have done ds35 mod, always know when its gonna do something because it starts to twitch flick it does this a couple of times then lets go causing pyro, lift again and all is good for a minute or so then repeats. Don't even have to be touching rudder and still does it.
    help.......
    If your not flying .....then make sure you crash with style
    Mine did the same. The umbrella gears in the tail were worn. They looked absolutely fine, only by holding the tail rotor and GENTLEY rotating the main rotor could you see the slipping (or vice versa).
    Trex 700 DFC - Vortexted, TRex 600, OUTRAGE FUSION 50, 500ESP, 450PRO, 130x.
      No tried that even locktighted both the gears on the tt rod to double check.
        Either your gears are worn, or your servo needs to be moved on your boom
        T-REX 250 DFC: Hyperion HS2206-3900 / YEP18A / Mini K-Bar
        T-REX 550 DFC Pro:
        AR7200BX BeastX - Soon to be... Spirit FBL / CC Phoenix Edge 100 / CC Bec Pro / Optipower Ultraguard
        DX8: Turnigy 4000mah Lipo
        Pheonix v5.
          Gears are fine upgraded metal main. The servo position is interesting does that make a difference?. Mine is about 12mm down the boom because I had to cut slide bar and re bend it for the ds35 servo horn.
            It does, because it's position on the boom dictates the central position and throw you get at the tail
            T-REX 550 DFC Pro:
            Pheonix v5.
              Ok thanks. Well I've straitened slide rod now and pushed servo back against mainframe will try now and post result. Thanks again.
                There are two trains of though in my head on this, position it so when the servo is in the center of it's travel then the tail is also in the center of it's travel too, or position it so the tail is roughly at hover pitch when the servo is centered.
                Test and report back, i'm going to be doing the DS35 to mine in the next couple of days
                T-REX 550 DFC Pro:
                Pheonix v5.
                  Tested and its worse no warning just pyro,d and heavy crash popped both cyclics...... So nope position didn't affect it.
                    If it's worse maybe it needed to go the other way
                    T-REX 550 DFC Pro:
                    Pheonix v5.
                      Check the tail boom isn't split.
                      I had the same problem, checked gears, servo etc.
                      Turned out the tail boom was cracked allowing it to twist.
                      I looked ok by looking at it, but gave it a twist and the crack appeared
                      Blade 130x
                      Goblin 500
                      Trex 700N DFC Redline 100
                      + Planes
                      + HPI BAJA
                        Bingo!!!! Tail is split at the end under the tail grip holder. Thankyou....
                        Next prob where can I find the cyclic servos in the uk.......
                          help.......
                          I had this problem and found the pitch slider and its bearings had worn causing slop in the tail. I fitted a upgraded double bearing pitch slider Lynx Heli Innovations 130 X DoubleBearing Tail Pitch Slider LX0304
                          problem solved
                            Midland Heli's showing them in stock
                            T-REX 550 DFC Pro:
                            Pheonix v5.
                              Nice one. Can't believe both popped the tops duh. And as above answer can't be the bearings as I've fitted rkh slider and case about 2 wks ago.
