Looks like it couls be a possibility, but only when using their frame, if you look at the frame HERE it looks like it has a much larger clearance space between motor and main shaft than the standard plastic item.
T-REX 250 DFC: Hyperion HS2206-3900 / YEP18A / Mini K-Bar
T-REX 550 DFC Pro: AR7200BX BeastX - Soon to be... Spirit FBL / CC Phoenix Edge 100 / CC Bec Pro / Optipower Ultraguard
Do you think ds35 as cyclic servos would handle a crash as well as stock ?
I've been through 4 cyclic servos already, partly due to wear & tear or crash damage. The ds35 come with 1 year warranty, just wondering if it's a better option in the future?
