Spectrum DX10T / Blade 130x
  • Spectrum DX10T / Blade 130x
    Please does anyone have the DX10T settings for the Blade 130x
    Interesting if somewhat unlikely combination
    You should be able to use DX18 settings if you can find them and DX8 will not be too different either.
      The DX8 settings should be fine, there is nothing special behind them, just 5 point pitch/throttle curves for N/UI1/IU2 and 0% hold.
      T-REX 250 DFC: Hyperion HS2206-3900 / YEP18A / Mini K-Bar
      T-REX 550 DFC Pro:
      AR7200BX BeastX - Soon to be... Spirit FBL / CC Phoenix Edge 100 / CC Bec Pro / Optipower Ultraguard
      DX8: Turnigy 4000mah Lipo
      Pheonix v5.
        Many thanks for guidance. Now flying all my helis on the DX10t but had to reset everything such as subtrims on all of them, Blade 130x,T-Rex 250, 450,500,550 and 600, except the 700 which for some reason was ok
