Tail twitching?
  • Tail twitching?
    Hi,
    Been flying most of the day with the 130x, been good.
    It seems to have developed a twich in the tail?
    Anyone had this?
    ALIGN TREX 250 DFC
    SPECTRUM DX8
    www.southhantshelis.co.uk
    Suggest you check that the tail unit is firmly pushed forward as mine did that last week -result being no tail control with a permanent pirouette!!
    Once I did that , no more probs
    Sab Goblin 570
    Sab Goblin 500
    500E Pro dfc
    450 Pro dfc
    Blade 300X
    DX9
      Mine was caused by the pitch be slightly out in the tail blades...
      Oxy 2, 180cfx, 130X
      Goosky S1
      DX 8 , Phoenix sim, DJI P3P
        Well, cleaned the servo and pushed the little tail bar back in slightly as it looked like it had come out slightly and looks like its gone.
        That was strange, I think the servo must of had something in it, hmm.
        I will say the 130x does keep me thinking what is going to go wrong next.
        ALIGN TREX 250 DFC
        SPECTRUM DX8
          i know what you mean, im still learning so i got a 130x as it was said can take a knock, i had one tail strike result = rounded inner tail drive, had one blade strike my fault and stripped main drive cog, then today took it to a big open field in the air prob 30 secs gust of wind hit it i panicked as it was getting away from me so hit throttle hold and hit the ground result = broken blade grip ball joint, i have had it a wk now ...... pilot error i know but got a msr x and thats taken masses of hits and only broken skids.
          If your not flying .....then make sure you crash with style
            Unfortunately the bigger they get the harder they crash, larger mass and more momentum/inertia mean more broken bits, once you get up the sizes a crash will usually cost at least £100 to put right (blades/boom/feathering spindle) so in that respect these little things are quite cheap to fix and keep airborne
            T-REX 250 DFC: Hyperion HS2206-3900 / YEP18A / Mini K-Bar
            T-REX 550 DFC Pro:
            AR7200BX BeastX - Soon to be... Spirit FBL / CC Phoenix Edge 100 / CC Bec Pro / Optipower Ultraguard
            DX8: Turnigy 4000mah Lipo
            Pheonix v5.
              To be fair, an mSRX is much smaller, is fixed pitch so much lower headspeed and is less complex (fixed pitch direct drive tail rotor). It's not that surprising that it takes more of a beating. Compared to a Trex250, Blade 300x or higher, the ability of the 130x to take knocks is pretty much second to none.
