How long have you got to hit throttle hold???
  • How long have you got to hit throttle hold???
    I'm a bit slow on hitting throttle hold after a crash in idle up. How long do you have to switch the motor off, is there any sort of current limit or does the electronics board go up in smoke?
    Blade 130-X, MSR, MSRX
    Phoenix Sim
    If the model starts piroetting hit hold imidiatley, if your just having or the heli is having a bit of a moment then hit hold a split moment before impact. If not it will just go nuts until something breaks but it wont burn out afaik.
      Hit it as soonas you think its going in the less power the better it may save more parts also. If it is on-the- ground then with motor still going there's a good chance the pinion will strip the main gear if nitro it Burns the clutch etc without the power it wont do a chicken dance across the field. Hope this helps I know this from expensive experience
      its full of meaty goodness
      GAUI NX 7 V Bar silver line
      Align T Rex 700 F3C Flybarred
      Align T rex 600 le DFC Vbar blue line
      SAB Goblin 570 Kontronik jive + pyro
      450 pro DFC
        I've got pretty quick at hitting the switch before the heli hits the long soft grass...
        As soon as I know 'all is lost' I just hit the switch and fly again...,it is easier than hoping for salvation and then replacing bits
        Hmmm....
        Trev
          As said as soon as it goes pete tong flick the switch, This will save you money, I find that info helps me to call it quits before it goes in
          DX8
          Phoenix
          RealFlight 7
          Mcpx BL
          Trex 550 DFC with Vx1n
          Trex 700 DFC Pro Hv with Vx1n
          Zmr250 mini H Quad racer
            RC Helicopter Crash Funny !!! - YouTube
            Think of this on a slightly smaller scale
            DX8
            Phoenix
            RealFlight 7
            Mcpx BL
              The sooner the better, the longer between hitting the switch and it going in the less inertia there is still stored up in the blades etc
              T-REX 250 DFC: Hyperion HS2206-3900 / YEP18A / Mini K-Bar
              T-REX 550 DFC Pro:
              AR7200BX BeastX - Soon to be... Spirit FBL / CC Phoenix Edge 100 / CC Bec Pro / Optipower Ultraguard
              DX8: Turnigy 4000mah Lipo
              Pheonix v5.
                Yeah definitely hit hold at the first sign of things going wrong. It will usually save you main gears, torque gears, clutches and possible ESC issues. I have been lucky enough on many occasions to just put a link back on or replace a broken link and fly away again. The faster the better with TH.
                Sponsored By
                Goblin 500-V bar T-rex700N with FLYBAR.
                http://www.lindensmfc.co.uk/
                  I know about the as soon as possible bit, but I was wondering how long it would survive before it smoked.
                  Phoenix Sim
