130x tail shaft screw breaks
  • 130x tail shaft screw breaks
    I've had the screw that holds the tail blade grip to the tail shaft break during flight about 7 or more times now, lost 4 rakon grips. I read that they can break if you tighten them too much when fitting the grip but thats not the problem i have. I put a little loctite on them, is there anything else i can do to stop them from breaking during flight?
    Paz
    Goblin Black Nitro
    Goblin 380
    Oxy 2
    Vcontrol
    Leicester Heli Flyers Club
    Has anyone experienced this problem and have a solution?
    Paz
    Goblin Black Nitro
    Goblin 380
    Oxy 2
    Vcontrol
      Never had a problem with those screws myself.Very strange!
        Do you tighten the screws all the way or just enough to hold?
        i'm thinking i might be tighting them too much!
        Paz
        Goblin Black Nitro
        Goblin 380
        Oxy 2
        Vcontrol
          I've never heard of that happening so much, especially when you've thread locked the screws.
          Are you sure it's not the tail shaft that's at fault? A mate of mine had a problem with his first replacement shaft that didn't have the the screw recesses deep enough so that screws were always loose. Certainly, for it to have happened 7 times, you've got to think the problem might lie with the common component?
            Everytime the screw breaks in the tail shaft the shaft can no longer be used as i cant get the screw out. Its not as common as i thought, i'm going to only tighten the screws enough to hold and see if that helps.
            Paz
            Goblin Black Nitro
            Goblin 380
            Oxy 2
            Vcontrol
              I had a screw head snap of this weekend when I was putting a grip back on I had not overtightened it and its bloody annoying!!
              Charles - Align 500EFL Pro - Blade 130x - Blade mCPx v2 - Spektrum DX6i & Phoenix Sim
