130x spin 8000 motor
    FL have them
    Spin Brushless Out-Run Motor 8000kv 16D x 10H mm 130X SMT1610-8000
      Where you getting the pinions from Nick, FL don't seem to have them..
      Goblin 500 SK540 jive 100lv
      HD 500 SK540 jive 80 lv
      Oxy 3 SK540 minijazz20
        I have one 11 tooth pinion spare brand new in the packet if you need one . Although please check in the box as mine came with one hence I now have spare !
          Was 68%...when i go past 71% the lvc cuts in.
          10T on order
          Having done some research this morning you can't get a 10 tooth pinion to fit ! Because the dab is 16mm if you look there is no movement to push the motor backwards which you would have to do when fitting the 10 tooth ! Mines as far back as you can get it and there's no room to go further backwards I hop that makes sense !
            Thanks for the offer rob. I checked and there is a pinion with the motor.
            I know of a guy in Germany that will make bespoke hand made pinions that are works of art from my time messing around with walkera micros. I will ask him if he could knock up a batch of 9 & 10 T pinions.
              Well mine turned up today while i was at work so obviously when i got home i ripped the 130 to bits before tea, put the motor in and had a quick test hover in the kitchen
              I went for 80% flat and as it spooled up i was beginning to wonder if it would ever run out of revs!! it sounds powerful now
              I did a 4 minute hover with quite a few violent pitch pumps and was giggling like a little girl Its pretty fierce
              I do seem to have acquired a tail wag which im putting down to the mental headspeed so i'll hopefully cure that by dropping the rudder gain a bit
              Looking forward to getting it out for a proper beating, Crazy little heli
              Mine also came with a pinion so if anyone needs one, Shout cos i bought 2
              DX8
              Phoenix
              RealFlight 7
              Mcpx BL
              Trex 550 DFC with Vx1n
              Trex 700 DFC Pro Hv with Vx1n
              Zmr250 mini H Quad racer
                Something to watch for guys - apparently due to the width of the motor, a 10T may cause you to just rub on the elevator servo.
                Just something to check for if you fit a 10T on this motor.
                  Mate, you're so going to have to bring that with you next time you're at Phoenix. Just don't let Stoner crash it before I have a go!
                    It's close on the 11T.
                    I am having lvc issues with this motor so have bought an XP 12a so i can have a low cut off,im just to scared to fit it due to the soldering.May have to get a diddy soldering iron first.
                    What is 'flashing' the esc all about?
                    • #25
                      don't need a diddy iron, just a fine tip.
                      Flashing the ESC allows you to install firmware which has better features, even a governor mode. I think dylan at astroid designs sells pre-flashed versions
                      • #26
                        ordered one of these for mine missed it today so it will be here thursday carnt wait to try it out that the weekend :P
                        Tbs discovery quad
                        Align 700L Dominator
                        Gaui x3
                        mikado logo 480 Xxtreme
                        • #27
                          I must admit I'm tempted - it's got more mass than the HP08 which suggests more copper = more power.
                          Nick - what batteries are you using by the way? Probably more guilty of the LVC issues than the stock ESC?
                          • #28
                            Nano 300....think i will try the gens again.
                            • #29
                              Midland will have some 350mAh 65c packs in for it soon, combined with the 8000 motor its just going to explode ! cant wait lol !
                              • #30
                                I bet the gens 450mah won't have the same LVC issues, or at least will come much later.
                                Haven't tried the nano's for the 130X but on my brushless mCP X they didn't survive long before the heli just started dropping out of the sky mid flight.
