Flight with perfect CoG
  • Flight with perfect CoG
    Got the 130 flying nice today at the field by adding a tiny bit of lead on the tail,only had a tiny bit so with the cano off,lipo (300 nano)as close to the motor as i could it was bang on.I have redone it tonight for when the cano is on.
    The heli flies sooooo much nicer,piro's are better too.
    Very nice flying
      Looks bang on the money there mate !
      Raptor E700
      Raptor G4
        Gotta love these electrics
          Adding some weight to the tail has certainly made it better.First vid shows that with hands off piro's.
          Then i reduced the pitch endpoints to 90 and it bogs less
            mine with the indoor battery (miniaviation 300mah x 30c) weighs 18g and puts the C of G perfect, this then rewards the heli with super flight control, flips are on the button, and great all round control, when i put the overlander 350's on its more punchy outdoors but you can tell the difference, then if you put on the power house gens ace 450's performance is top whack but it flies heavy too
              how do you test the cog on these? The motor stops the heli spinning if you test it the normal way!
              TT Raptor G4 + Vbar
                just pop your battery in and canopy on, then hold the head 90 degrees to the floor and gently rock it back and forth, with the heli on knife edge, either the tail will drop (tail heavy) or the canopy will try to drop (nose heavy) or if it tries to stay level then your spot on,
