randam tail swing
  • randam tail swing
    Well not sure if it has any thing to do with the rotation but today the tale started letting go during flight.
    was hovering and doing some small slow circuits when the tail done a 180 held for about a second and then 're-set back to were it was heading wise it now keeps doing it every so often which is really strange could I need to adjust the heading gain or something I will probably ring HH on Monday for there ideas
    Main drive gear getting worn (that drives the tail gear)
    My started that today then let go completely
    TDR (in progress)
    SAB Goblin 700
    Vibe 90SG Vibe 500E
    Kalt Baron30
      D'oh found the problem Not the A gear as mine is metal upgrade. It was the push rod was too short so it was torsion from the main rotor . Seems fixed for 2 batteries so will keep an eye on it
