I bent my tail shaft which i got with the MH tail grips. I just noticed the stock shaft is slight different at the T end, means the MH grips bearings wont fix to the shaft completly.
Any one else noticed this or got MH tail grips to fit stock tail shaft?
I was thinking of replacing the MH tail grip bearing with the stocks ones but not sure if they will fit without damaging anything..
