I am on my 4th replacement Tail Shaft not because I broke 4 but because they all seem to be faulty?
Part No: BLH3731 The problem is the screw thread in the T Bar part of the shaft for holding on the Tail Blade Grips tightly. On all the parts I received, the screw goes in one end smoothly but will not go all the way in on the other side, whatever I try?!? If you tighten it too hard, the screw snaps inside the Tail Shaft which makes the part useless. If you do not fully tighten it, there is too much play in that tail blade grip which surely doesn't help with vibration issues. The original Tail Shaft is fine apart from being bent.
I was just wondering if this was infact a manufacturing fault or just a bad batch and just me being unlucky?
Does anyone else have a replacement BLH3731 Tail Shaft with the same issue?
(Please no "Call HH" or "Send it Back" comments, just curious)
