I was just wondering what throttle curves everyone is using? Also 40% expo seems a bit much and duals rates 85% in i.u 1?
throttle curves+dual rates, expo
Ok, in normal flight I use a throttle curve on most models of 0, 45, 65, 85, 100. Idle up I use 0. 25. 50, 75, 100. All with flybarless helis.
I don't like much expo and rarely use more than 15%. Dual rates I do use: 85% in normal flight but 100% in idle up.
But it is personal preference with expo and dual rates. Pitch curves are -12 to +12° in idle up and -4 to +11 in normal flight.
DomBIG BAD DOM
Compass 7HV, Compass 4926-510KV motor, AR7200BX, Castle Ice2 120HV, MKS BLS950/980 servos
Mikado Logo 600SE Uvular, Scorpion HK4035-330KV, Ikon flb, 12s setup
SAB Goblin 500, Quantum 4115-1200KV motor, AR7200BX, Kontronics Koby 90, MKS DS9670A+ servos, Align DS650
Eflite Blade 130X, 8000kv outrunner, all Lynx upgrades including DFC head
No dual rates? I would stick about 15-20 expo in, I was out yesterday with it and it seems at bit numb with the stock settings. Flips rolls were a bit slowOriginally posted by Geek View PostMines easy
100% throttle 0% expo
And loving it.
Think if you are newbie then some expo
Also love it
Sab Goblin 500
100% D/R's 30% expo, gives full travel, and some nice soft centre for when you are scooting along a few inchs above the ground.
if u like it full on
100% DR and neg 5% expo , and hang on to yer hat ! because this little thing really movesCurrent Heli's, Align Trex 550, Blade MCPx BL, Blade 130x, Blade 450x, JR DSX9
That sounds about right for me personally, will give something like that a go, the stock settings aren't right at all. And I have no idea about the pitch range tooOriginally posted by AcidDrink View Post100% D/R, 100% flat TH, 15% expo, linear -100/100 pitch curves, I have no idea how much pitch it gives.
Sab Goblin 500
