130X power problem
  • 130X power problem
    Hi All got the bits to sort the tail blade ejection problem out and finally got to do some proper testing approx 10 fun filled flights later goes to spool up and it only goes to what seems 1/3 throttle just about enough power to take off with not much controll. I have rebound it but its still the same. The model was spot on the flight before and i always end the flights with a small auto. It feels like a flat lipo but I have tried a few and its the same on all of them and the connections are all tight any thoughts ???
    iCharger 4010 , PL8 charger,
    Esc to motor wires? having one disconnected will result in a motor that turns slowly. Best guess.
    Mikes Place - Home of the golden dump.
    Sponsored by Elite Models.
    http://www.elitemodelsonline.co.uk/
      Just spoken to Horizon and they suspect a faulty fet on the board so it will have to go back .
