DX7 help
  • DX7 help
    Just picked up my 130x, going through the set up and the destructions call for gyro sens @ INH, I can only get my DX7 [ old style] to show in gyro sens menu
    Rudd D/R rate 50% 50% or switch to auto.
    How do i INH it??
    Cheers......
    Goblin 500 SK540 jive 100lv
    HD 500 SK540 jive 80 lv
    Oxy 3 SK540 minijazz20
    In your model select menu. Make sure you have the correct model selected then scroll through the menus to the input select screen.
    In there you have the aux2 and gear channel selectors one of these will be set to gyro. If you change this to inh the gyro menu will drop.
    Hope this helps
    All the best
    Tony.
      i had the same problem
      there's a mistake in manual cause it's said to select gyro in input select and then select inh in gyro select
      DX7 mode2
      Gaui nx4
      T700n
      miniprotos fbl 4s
      voodoo 600
      logo 600 3D for sale
        Thanks guys, got it!! As ducati said, there is a mistake in the manual. Cheers..
          Yes I thought it was a bit pointless setting gear-gyro in the config menu especially when your going to disable it anyway. This explains quite a lot thanks
          Martyn
          Blade 400, Outrage G5 FBL, Align 500/600
          DX7, DSX9
            to be fair when using the DX7 I never did activate the gyro menu as the gain went through the gear channel and therefore the endpoints were used to change the gain.
            and the gear switch used to switch between heading and rate mode.
            All the best
            Tony.
