What is causing the wobble?
about 30 seconds later the heli started shaking even worse so i landed. as i went to take off it lost tail rotation and i discovered the brand new metal tail gear was now missing.
i got out a little electric baton and wire locator and to my surprise i found it in the grass.
the only thing i can think is that the tail case wasnt pushed home enough?
i will redo it this afternoon.
i just did not think it would cause a head type wobble1x EGS, TREX 450 PRO DFC & 130X. DX9 radio. No idea what i am doing trying to fly
ho boggy
what is the best settings for a standard gyro settings on the 130x ???
cheers rogerBLADE 350X * BLADE 130X 1 * BLADE 130X 2 * BLADE NANO CPX * BLADE MCPX X 2 *
BLADE MCPX BL * BLADE 120SR *BLADE 200 MSR *
2 WINGS
TX SPECTRUM DX6I DX9
I like the std factory settings Roger never changed mine. To get rid of the horrible paddy it can suddenly throw I fitted canopy grommets sliced in half. (one bit on the inside of each swash ball.)
Mine has a head wobble side to side especially when flying into the wind. This is mainly exhibited as the skids wobbling sideways.
Feathering spindle / dampners?Happy Landings.
David
Raptor 50. OS50
Mcpx
Blade 130x
Goblin 500
Oh does that work with the 130x as well? I might try that as mine has a fit every now and again.Originally posted by Boggy View PostI like the std factory settings Roger never changed mine. To get rid of the horrible paddy it can suddenly throw I fitted canopy grommets sliced in half. (one bit on the inside of each swash ball.)Pete
Lynx Heli Team Pilot
hi ron
thanks fer input i am trying to get my 130x to gyro default ??
i have throttle stick 100% tx on plugged lipo in to 130 as said all i have is a constant blue light ???
help lol
2 WINGS
It may not be seeing the high stick position as full throttle Roger. Go into the tx menu and raise the high throttle end point up.
