Progress With The Blade 130x - Your Advice Required
  • Progress With The Blade 130x - Your Advice Required
    So I took you advice, in fact, I went a bit further and bought some other bits for the 130x.
    I got the following:
    Lynx Tail Boom mod - Not installed
    Lynx Tail Boom supports - Not installed
    Xtreme Carbon Fiber Blades 135mm - INSTALLED
    Lynx Tail Rotor Blades - INSTALLED
    I have noticed the following since installing the new blades.
    1. No tail vibration at all.
    2. Very skittish on take off over the standard blades. Its almost like it had too much torque. Once its flying its fine, but getting it of the floor is a little challenging.
    I will post a video tomorrow (To tired now) but look forward to seeing your comments and advice in my morning time
    One more thing - I used this guys settings http://www.youtube.com/watch?v=pvcDO6U-CAA not sure if thats gonna be an issue.
    Thanks all.
    Blade 130x
    Blade MCPx
    DX7S
    CF blades!!! Not really a beginner mod. I'm not sure what your standard of flying is but be careful. I've never used them on my 130X as they will break easy and are expensive. I hear that they make the 130X more crisp as they are a firmer blade and won't flex like the plastic ones. Let us know how you get on with them
    Oxy 2, 180cfx, 130X
    Goosky S1
    DX 8 , Phoenix sim, DJI P3P
      I used to fly a 500 and 600, not very well but I never crashed them
      So I took it out the front this morning and its not happy with those blades taking off. Once its in the air its stable. No i did have a scare. On the second battery I spooled the heli up and the tail blew out on the ground. I cut the power, no damage. I then flew again and about 20s into the flight the tail blew out again. Luckily we have had a foot of snow so no damage to the heli.
      I wonder if the settings I have are not right for those main blades?
      I am going to put the old blades back on to see what happens.
      Blade 130x
      Blade MCPx
      DX7S
        Check your 'C' gear on the TT isn't rounded out. Could be the cause of your tail blowing out. Doesn't take much.
        ​Danny
        Dx9
        130x
        Goblin 700
        CGM neXt
          I will check that - After the crash into the snow I cant get into the air now and I dont have much control of the tail. I put it back to stock but that has not changed things. when I spool up it just seems to want to to to face me. Take a look at the video.
          http://www.shaggysworld.com/helo/2.mp4
          Blade 130x
          Blade MCPx
          DX7S
            The gear look good too - Nice sharp edges.
            Blade 130x
            Blade MCPx
            DX7S
              Now what i did notice - and I'm no expert. Is that the the gear below (at the main rotor end of the torque bar) slips. and if you look at the picture there is loads of dust in there too. I am not sure how sharp that gear should be but it looks pretty flat. Now this could explain why i tended to get the screeching and slipping noise when I first flew the heli?
              Let me know you thoughts. I think its called the bevel gear.
              Blade 130x
              Blade MCPx
              DX7S
                Edit: That main gear is knackered, replace it with the metal 'A' gear.
                ​Danny
                Dx9
                130x
                Goblin 700
                CGM neXt
                  that gear is knackered well and truly
                    In that case, since its only had a total of 6 batteries through it. 4 of them indoors I will take it back to the dealer. What you think? I'm assuming that's a manufacturer defect?
                    Blade 130x
                    Blade MCPx
                    DX7S
                      Don't think my one lasted that long either but I crashed mine a lot when I first got it, was the first CP I ever flew. PM me your address mate and I will send you a metal 'A' gear
                      ​Danny
                      Dx9
                      130x
                      Goblin 700
                      CGM neXt
                        Thanks that guy - That's really appreciated. I am in the US though - An Englishman in New Jersey !!! I have Go Nitro Hobbies about 8 miles away where I bought this. I am going to take it back to them as it should not go within a week. I can probably get the metal gear from them. Unless you really ant to send it I can PM you, let know!! and thanks.
                        Blade 130x
                        Blade MCPx
                        DX7S
                          Haha! I should have looked at your location Probably cost more than the gear is worth to post.
                          ​Danny
                          Dx9
                          130x
                          Goblin 700
                          CGM neXt
                            Yeah, exactly - I think they should give me a new Heli - What you think?
                            Blade 130x
                            Blade MCPx
                            DX7S
                              Put it back to stock and return it to the dealer, if it has not been crashed and has just stripped they should replace it.
                              ​Danny
                              Dx9
                              130x
                              Goblin 700
                              CGM neXt
