Servo Saver Mod
  • Servo Saver Mod
    I have fitted the Lynx Heli micro servo arms to my 180CFX. However the tail servo arm seems to be a bit long once it is sat in a position. Should / does it need trimming down?v The arm appears to touch the frame when in the up position.
    Not sure the answer to your question. I've crashed my 180 a fair few times, I have the diy servo saver mod on the cyclics but nothing on the tail and never had a problem. I would just put the stock arm back on the tail
      OK thanks for the reply. Will put the stock arm back on for the time being. Is it worth doing the servo saver mod as an alternative on the stock arm?
        as above I've never stripped the gears on the tail BUT I lave now replaced the tail servo for a Spektrum servo after a slight tail wobble issue & now flys much better
        Goblin , 380 Carbon
        Oxy 4 - 360
        Oxy 4 - 325
        Oxy 3 - 250 , 3s
        Oxy 3 - 250 , 4s
        Oxy 3 - 280 , 3s
        Oxy 2 - 190
        Oxy 2 - 210
        Spektrum DX9
        Revolectrix PL6 & PL8
          Which spectrum servo? The 3060?
          i have the diy servo saver mod and did the tail servo also. Not stripped any gears after a few crashes all is good on the servo gears. The servo horn/ arm on the stock tail servo 76t has been cut short also. So not an issue.
          Oxy 2, 180cfx, 130X
          Goosky S1
          DX 8 , Phoenix sim, DJI P3P
            yes Spektrum H3060 on the tail , had to modify the frame slightly but well worth the effort
            Goblin , 380 Carbon
            Oxy 4 - 360
            Oxy 4 - 325
            Oxy 3 - 250 , 3s
            Oxy 3 - 250 , 4s
            Oxy 3 - 280 , 3s
            Oxy 2 - 190
            Oxy 2 - 210
            Spektrum DX9
              What's the specs compared to the stock tail? I am finding the stock tail servo a little slow. Did you have to adjust any of the PID settings with a different servo than stock?
              Oxy 2, 180cfx, 130X
              Goosky S1
                I don't know if it's any faster but you can look up the specs on the internet, it is a straight swap apart from a slight mod on the frame
                Here's a link to a thread on helifreak about the mod
                Finally got the H3060 tail servo installed (pictures) - HeliFreak
                Goblin , 380 Carbon
                Oxy 4 - 360
                Oxy 4 - 325
                Oxy 3 - 250 , 3s
                Oxy 3 - 250 , 4s
                Oxy 3 - 280 , 3s
                Oxy 2 - 190
                Oxy 2 - 210
                Spektrum DX9
                  Yes I have read the mod thread for the 3060 tail servo. Looks like a good choice. I will look up the specs then and see if it's faster than the eflite one
                  Oxy 2, 180cfx, 130X
                  Goosky S1
                    So I can't find the specs for the h3060 but the 76t looks fast! Says 0.03s/ 60° at 4.8v may have to strip the tail and have a look as maybe I got binding. The eflite should be way fast enough.
                    Oxy 2, 180cfx, 130X
                    Goosky S1
                      Here is the specs
                      https://www.spektrumrc.com/Products/...odID=SPMSH3060
                      Goblin , 380 Carbon
                      Oxy 4 - 360
                      Oxy 4 - 325
                      Oxy 3 - 250 , 3s
                      Oxy 3 - 250 , 4s
                      Oxy 3 - 280 , 3s
                      Oxy 2 - 190
                      Oxy 2 - 210
                      Spektrum DX9
                        Ahhh found the specs for the h3060 it's 0.06 slower than the eflite 76t...
                        76t:
                        Product Specifications
                        Size Category: Minis and Micros
                        Type: Digital
                        Application: Helicopter tail servo
                        Torque: 11.1 oz-in (0.80 kg-cm)
                        Speed: 0.03 sec/60° @ 4.8V
                        Length: 0.90 in (23.0mm)
                        Width: 0.45 in (11.5mm)
                        Height: 0.96 in (24.0mm)
                        Weight: 0.27 oz (7.6g)
                        Motor Type: Coreless
                        Connector Type: Universal
                        Gear Type: Nylon
                        Voltage: 4.8V - 5.0V
                        h3060:
                        PRODUCT SPECIFICATIONS
                        Size Category:Minis and Micros
                        TypeigitalApplication:300-450 Sized helicopterTorque:12 oz-in (0.9kg-cm) @ 4.8V; 15.75 oz-in (1.1kg-cm) @ 6VSpeed:0.036 sec/60 deg @ 4.8V; 0.029 sec/60 deg @ 6V, at no loadLength:0.91 in (23mm)Width:0.47 in (12mm)Height:1.17 in (29.6mm)Weight:0.46 oz (12.9 g)Bushing Or Bearing:BearingBearing:SingleConnector Type:UniversalGear Type:MetalVoltage:4.8V to 6.0VDeadband:2
                        Oxy 2, 180cfx, 130X
                        Goosky S1
                          You must be faster at typing then me
                          Oxy 2, 180cfx, 130X
                          Goosky S1
                            I've never found the tail to slow for me , there may well be something not quite rite in the servo or tail mechanism
                            Goblin , 380 Carbon
                            Oxy 4 - 360
                            Oxy 4 - 325
                            Oxy 3 - 250 , 3s
                            Oxy 3 - 250 , 4s
                            Oxy 3 - 280 , 3s
                            Oxy 2 - 190
                            Oxy 2 - 210
                            Spektrum DX9
                              I think that the pitch slider is catching at one end. Not easy to adjust the end points of the tail on this model. Also do you know or have a link helping with the PID gains?
                              Oxy 2, 180cfx, 130X
                              Goosky S1
