AvantGarde flight logs ( CC Ice 2 HV 120)
  • AvantGarde flight logs ( CC Ice 2 HV 120)
    Hi,
    i have put some logs online of the CC 120 ICE2 HV.
    http://www.beam-helicopters.com/logs/nmxohb2011.zip
    If you open them with the CC log viewer, you will see 7 different sessions. The 6 first ones are test flights with one that was a continous power test ( no load, no pitch, just to check motor behaviour and temperatures).
    The last session ( session 7 ) is Nick Maxwell flight at Orlando Helicopter Blowout.
    Heli setup was on this flight:
    - Optipower batteries, 2 x 6S 3000 mAh ( 2nd cycle, they were brand new batteries)
    - Outrage 4125-560 kV motor prototype, it was given for 3000 watts continous, i let you see by yourself on the logs on how high this little guy can climb when requested )). And it did not heat up, it's 30 flights more or less now and i had no issues at all with this motor...
    - Gryphon Quasar HV Bec
    - Nexus 616 MG HV servos on swash
    - BLS 251 with stepdown on the tail
    - BEast X V3.08, cyclic acceleration and pitch boost disabled
    - Gryphon 615 mm main blades, FBL
    - Radix 95mm tail blades
    - Spektrum DX8 with AR 8000 receiver
    - Motor pinion : 13T
    Best regards,
    Fabien
