New black helical auto gear on 700 nitro makes horrible noise
  • New black helical auto gear on 700 nitro makes horrible noise
    I recently decided to change all the gears on my t-rex 700 nitro to the new black ones. The helical pinion and main gear are fine but the new black auto gear made a horrible noise. It was so bad I have had to change back to the original straight auto gear. Has anyone else had this problem with the new black auto gear?
    Ali
    T-Rex 700N - O.S. 105 HZ-R, VBar NEO (Pro), cyclic - Align BL815H, rudder - Align BL855H, new Align 700 mm main blades, Rail 106 mm tail blades.
    T-Rex 700X - 850MX, Align RCE-BL130A ESC, VBar NEO (Pro), cyclic - Align DS820M, rudder - Align DS825M, Align 700 mm main blades, Align 106 mm tail blades.
    VBar Control TX
    Did you push in enough to get correct mesh to gear
    Santander Factory Team
    Proud wearer of 5 x EGS
      Odd....I have 3 machines soon to be 4 all with black main, auto and tail gears no problem here...
        No probs here, how tight is the mesh?
        Henseleit TDR V-Bar x2
        SAB Goblin 700 V-Bar
        T-Rex 700e DFC V-Bar
        Synergy N7 V-Bar OS105 HZ-R
        Synergy E7se V-Bar
        Synergy N5c FBL V-Bar
        Gaui NX7 V-Bar YS91 Tareq SRX
        T-Rex 550 E FBL V-Bar
        Gaui NX4 V-Bar
          Mesh is fine. Did your models sound a lot quieter after changing to the helical gears?
          Ali
          VBar Control TX
            A little yes
              I know i dont have the black gears, but on my 700n DFC the main and tail auto gears (helical cut) are extremly quiet and mesh really well.
              Maybe you got a duff gear tht wasnt consentric?!?!
                Alex has been using the black tail and drive gears on his 700e DFC when Align "up graded" them at the start of the year.
                When I fitted these gears back in January the tail drive felt notchy and a little stiff, and produced quite a bit of whine when being used. After a short time this noise eased off and the notchy feel disapeared. I found these gears to be very tight in the bearings ad a bit of a pain when adjusting the positioning to get the best / smoothest fit available.
                Peter
                Member of Milton Keynes model flying club
