700 reg
  • 700 reg
    evening,
    does anyone run their 700 with the supplied 2 in 1 or is it advisable to switch it out for something else,ive been looking at the gryphon reg,this covers 1 side of it but what about the glow,will the autobooser work,running dx8,v-bar,os 105
    vinny
    SPY750 CLASSIFIED in build
    TBS DISCOVERY enroute
    Trex 450 pro in bits
    I wouldn never use the Align 2 in 1 again!!
    On my 600 im using the FlightTech 10 amp reg
    On my 700 im using the Gryphon Gryphon VEGA Regulator 10A Linear Voltage Regulator GVR-5010
    I dont use an auto glow as i want to save weight on the heli so i just use a glow extension and external glow driver
      Hi Vinney I use the Gryphon Vega...and Gryphon now do a mini booster I would not mind a couple of them myself..... Gryphon Mini Auto Booster (Touch switch type) GAB-3300
        ive seen the mini booster but looking at this 1
        Gryphon Auto Booster Remote Operated Glow Igniter GAB-5500
          When I had a RX I used them and it worked from my TX...but never sorted how too get it too work with the V bar...the extreme reg only does 4 servos at the set voltage so you will have too run the throttle at 5.2 but thats know big deal...with the Vega you just set the voltage and plug the 2 power leads into the V Bar very simple and no patch leads...then take the power from a spare port for the mini booster.....
            ok,ive got a hv on the throttle so the extreme would be ok but the vega does sound like a neater installation,mini booster should be good also,no messing about trying to get it sorted with the tx/rx
            cheers chris and john,think it'll be the vega and mini booster
              When is the maiden then...got a starter here if you need one too use......
                not sure john,this build has being going on since mid december,i wouldnt be surprised if there is a new 700n out by the time i finish it,not much time at the moment
                  For what reason would you not use again chris? serious failure? reason i ask is ive had the original align 2 in 1 fitted on one of my 700,s for well over a year and half with no problems whatsoever! but i do have a flightpower 8a reg here looking to be fitted ,would you recommend it
                    I used to use them before and I dont recall any issues but have heard of may failures with them.
                    % wise its prob quite low??
                      Its best too take our time with these sort of things nothing gained by rushing.....
                        what about govenor,is there 1 available that doesnt use magnets?
                          Originally posted by Telehandler View Post
                          serious failure?
                          the only thing i've seen anybody moan about is the switch, i've been using one myself for a wee while and i've had no problems at all so far.
                            using a spekky ar7100r here vinny where the gov works of back plate sensor,
