Black TT Gears
  • Black TT Gears
    Guys, are these the new TT gears that Align used in this vid?
    ALIGN New Torque Tube Drive Gear Coming soon! - YouTube
    H7NG001AXT | T-Rex 700 M1 Torque Tube Front Drive Gear Set/21T
    H70G005XXT | T-Rex 700 Torque Tube Rear Drive Gear Set
    Henseleit TDR V-Bar x2
    SAB Goblin 700 V-Bar
    T-Rex 700e DFC V-Bar
    Synergy N7 V-Bar OS105 HZ-R
    Synergy E7se V-Bar
    Synergy N5c FBL V-Bar
    Gaui NX7 V-Bar YS91 Tareq SRX
    T-Rex 550 E FBL V-Bar
    Gaui NX4 V-Bar
    yup thats the upgrades .. make sure you also grab the main gear ...
    Sev
    Thunder Tiger E700 BD3SX
    Trex 450L DFC BD3SX
    Trex 150 PRO DFC
    Blade Nano CP X
    Blade mCP X v2
    Blade 130X
    DJI Inspire 1
    DJI Phantom 2 iOSDmini
    EMAX 250 Pro V2 FPV Racer
    Futaba 18MZ
    MK Heli Club MKMAA
    Proud Owner of:
      Yes they are Rob
      Avant mostro 700E
      Avant mostro 700 Nitro
      member of :
      South cheshire heliaddicts
        Which main gear? Do you mean the M1 auto gear?
        I was thinking of changing to the M1 helical main gear with a new helical pinion, what do you all think?
        Synergy E7se V-Bar
        Gaui NX4 V-Bar
          Youll have to anyway rob if you want to use those gears. The crown gear is helical.
          You also need the V2 tail grips as the v1 one wont fit the new hub.
          Avant mostro 700E
          member of :
            Next question!!
            21 or 22T front gear set, and what tooth count on the main? Using YS91SRS
            Synergy E7se V-Bar
            Gaui NX4 V-Bar
              21t, the 22 is for the E
              Avant mostro 700E
              member of :
                So if we upgrade will the quick uk tail fit on the new tail drive??
                Avant ultimate, YS91srs, Hatori, vBar, JR HV, Edge
                T700, YS91srs, Hatori, vBar, Torque 9088/9188, Edge
                Logo 700 Xxtreme, Scorpion, Helijive, HC3-sX, BLS 451/251, Edge
                Logo 600sx, Pyro, Helijive, vBar, BLS 451/251, Edge
                Logo 500se, KDE, Jive 110lv, HC3-sX, BLS 451/251, Edge
                T550, Pyro/Jive 110lv, vBar, BLS 451/251, Edge
                T500, Pyro/Jive 80hv, HC3sx, I2 head, Edge
                  sorry mate, just saw in your sig that you dont have the DFC - for the DFC there is a new main gear out H70G002XXT CNC Slant Thread Main Drive Gear/112T (Use for T-REX 700N/E 800E.)
                  Sev
                  Trex 450L DFC BD3SX
                  Trex 150 PRO DFC
                  Blade Nano CP X
                  Blade mCP X v2
                  Blade 130X
                  DJI Inspire 1
                  Futaba 18MZ
                  MK Heli Club MKMAA
                  Proud Owner of:
                    Same question as rctintin, nitro 700. I take it the standard helical pinion is ok, then use the new main gear front gear set and rear set plus drive.
                    there is a 110 and 112 tooth main gear set. Which is for nitro if you are upgrading the lot? Incidentally both 110 and 112 are in trex 700e packaging! ( I have them in front of me)
                    thanks
                    stu
                      Reading some more here so my t700 is DFC geared (white style helical main and auto down to the new tail box. If that is the case what:
                      main ggear front gear and rear gear do I need to get???
                      thanks
                      stu
                        I dont think so no, the v2 grips and the new style hub use a larger ID bearing.
                        Avant mostro 700E
                        member of :
                          I think I will call Matt at Midlands in the new year with my loveeeerrrrly 10% code, and get him to decide which main gear matches this all up on my 700LE nitro.
                          I still have the original main gear with smaller pitch, so because there is no mesh movement on the nitro, it has to be the correct M1 gear to fit.
                          Synergy E7se V-Bar
                          Gaui NX4 V-Bar
                            glad to see that the new hub comes with the thicker washers now too
                            Avant mostro 700E
                            member of :
                              Do you guys know if these TT gears are available for the complete range of Align helis or is it just the 700
                              The Fleet
                              Trex 450 Pro on Brain 2
                              Mini Titan super Cobra ah1
                              Alien 550 Quad.3DR Pixhawk
                              Futaba 7C 8FGS 14SG
                              Specktrum DX6i
