A little hint with the OS105 - Mine came and I didnt check the needle settings. They were waaaay off (Much leaner than the manual said they should be)
Once i reset them to the stock settings, the heli wouldnt even spool up properly. I actually burnt out a clutch trying to get it to spool up, I didnt realise what was going on and the clutch was slipping constantly even though I was flying just because the engine was so pig rich it didnt even have the power to reach a proper RPM and engage the clutch properly. Run it with the stock needle settings by all means, but just make sure your clutch isnt slipping or anything stupid when you do. I think mine was caused by a combination of being really rich and a low throttle curve. I had to lean my mid 8 clicks from 1 turn out just to get the thing off the ground properly.
Stock settings are a full turn out on the mid and 2 and a half on the high I think. So far I've got down to 1/4 turn out on the mid and just over 1 turn out on the high and its still really rich on the high end (I think) Im running the small shim in the engine and 20% optipower with a standard #8 OS plug. If your around dagenham way we could go fly sometime, Im in watford.
,makes a change from building electric heli's,quite exciting stuff
