Dfc nitro canopy
  • Dfc nitro canopy
    Hi all,
    Anyone know if the regular 700 nitro canopy (v2?) fits on the new 700 dfc nitro?
    If so, any pics, or does it look the same as if mounted on a v2?
    Thanks,
    Ryan.
    No, Andy already tried it Ryan, sits far too high. You would have to do some work with the dremel
      Cr@p, I like the new style, just not the colours, worst combo I have ever seen for visibility!
      Thanks buddy.
        Plus it makes the nice new sleek look like a fat biffa
        Have you looked at the E version, that might fit
          As far as the mounting holes go, its a perfect fit, however, it is tight across the top. A mate has made up some form of spacers to widen the ordinary cano at the back, and apparently that works. Apart from that, it is shorter at the rear as well, ie not quite as sleek. But beggars can't be choosers, as they say..............
          HTH
          T-Rex 600N Pro x 2 - T-Rex 600N Sport - Rappy 50 - Hughes scale (Rappy 50) - Hughes scale (Century 50)
          Jet Ranger scale (GH 61) - Mini Titan - mCPx - A "few" canopies
          www.Cano-Fx.co.uk
            Thanks buddy.
            Really?? I love mine and think it gives good visability. Great shape tho, you will jus have to wait for fusuno and align to make more cano designs for the 700n dfc
              ive got my V1 night rigged one to fit my DFC Ryan, as Buckers says holes are spot on but I had to extend the rear mounts by about 10mm each side, just used a brass blade bolt insert and a longer bolt. It will rub on the main gear if you don't extend them. the front ones could be extended too but i havent bothered as im using QUK screws so just pulled it in with them.
              You can actually buy longer Align canopy mounts that are 10mm longer than the stock ones but they have been out of stock for a while.
              Here you go http://www.fast-lad.co.uk/store/exte...6-p-11755.html
              Avant mostro 700E
              Avant mostro 700 Nitro
              member of :
              South cheshire heliaddicts
                Oh and if you do end up using a v1 cano and want to sell me the DFC cano Ryan give me a shout!
                Avant mostro 700E
                member of :
                  Re: Dfc nitro canopy
                  You will be the first to know
                    I was also wondering about diff canopies but I guess my question has been answered!
                    Btw Ryan, I see an n9 in your sig. I sold my n9 with a few canopies and that was one of them. There can't be many about so maybe that is my old airframe? small world if so.
                      It was an early new N9 and I had that canopy done for me, with real raptors slapped on. I did sell it on in pristine condition though, after Andy lost the dealership, thanks to the aussie! I do miss that heli and canopy paint design, I had most my helis painted like it. (Dokey on rr)
                        well i ended up with that canopy in rough condition as a beater. my old N9 and your canopy ended up in germany and i'm sure it is still going. built like a brickhouse.
