600 nitro bearing block frame bolts....
  • 600 nitro bearing block frame bolts....
    .......The ones with the lug behind the head that fits into the oversize hole in the frame, stopping the main bearing blocks (and clutch) from moving. This lug/ridge restricts what bolts you can use if you want to replace the align ones. A little birdie told me that he thought it was possible to get adaptors that fit into the frame holes/or over normal bolts to solve this problem. If so, any idea who sells them. any links to them would be great.....
    thanks
    trex 550 (HC3SX)
    trex 600 nitro le (beastx)
    compass 6HV (Spirit)
    dx8.....
    its not my dog by the way.
    Here you go
    ST Products 600/700 Special Washer Orange 20720344
    Im sure other colours are available too.
    Avant mostro 700E
    Avant mostro 700 Nitro
    member of :
    South cheshire heliaddicts
      thanks tony, they will do the trick....but what i was after (in the ideal world) was just the spacer ring bit, so i can use a set of wide headed lynx frame bolts that I allready have. If someone makes them that is.
      trex 550 (HC3SX)
      dx8.....
        LYNX HELI , LLC
          Originally posted by Baldie View Post
          packs of 15 when you need 16 for the heli ! ....poor show from lynx. same with some of their other packs aslo.
          As above though, can you get just a small spacer ring to go over a standard bolt
          trex 550 (HC3SX)
          dx8.....
            Isnt that what i linked to? the bolts dont come with the spacers you have to buy those seperately.
            They will accomodate a 6mm bolt head or are your bolt heads larger than that?
            Avant mostro 700E
            member of :
              sorry tony, I looked at the link, and did not scroll down the page to see the dimensioned picture. The bolt heads I have are the size of the whole washer i think (edit, measured at 7mm). I was looking for the 4.5 x 3 x 1mm bit if its available anywhere
              trex 550 (HC3SX)
              dx8.....
