How do I translate Futaba Tx settings into Walkera Tx settings
  • How do I translate Futaba Tx settings into Walkera Tx settings
    I wondered whether you could offer advice on how I go about settings the following identified on page 26 of my Align FL760 when using a Futaba Tx. Here is a link to my manual http://www.walkera.com/en1/fileDown....expe.pdf&la=en
    Heli Setting Futaba menu setting
    Main blade pitch (collective pitch) main blade pitch 10deg ~ 12deg with swash pitch 33%~38% what does this do if my mechanical pitch is -2deg to +10deg
    Cyclic pitch AIL/ELE swash Cyclic pitch 10deg with swash AIL 40% and swash ELE 40% whats the difference between this and the next row?
    AIL and ELE swashplate mixing ratio Swash AIL <=40% and swash ELE <=40% ? as above
    AIL and ELE gyro gain settings 12 o'clock (50%) I understand this, but the gyro itself has a screw setting that can be set to 12 o'clock (50%) but the Walkera Tx can also assign a 0%-100% value??
    I've no idea how to translate the Futaba menu settings into Walkera Devo 10 menu settings , or what some of them do?
    thanks (in anticipation)
    Align 600 Nitro Pro 3D; Align FL760 3G FBL conversion; OS .50 Nitro; Turnigy Digital Servos (ELE,AIL); Spektrum Digital Servos (THROT,RUDDER); Align 2in1 Regulator and Electronic Glow Plug switched start; Walkera Devo 10 Tx and Rx kit; Fuel Filter; Heli Artist scale Airwolf with retractables.
