NIMH batteries okay for transmitter?
  • NIMH batteries okay for transmitter?
    My Walkera DEVO 10 can use 8xAA NIMH batteries, is it okay to use these or should i convert to LiPo as I note many others have done with their transmitters (of various manufacturer/models)
    It also has a charge port that accepts a charging plug (not supplied) that must be "DC 12V 50mA polarity +)-" where can i get such a charger?
    thanks
    Align 600 Nitro Pro 3D; Align FL760 3G FBL conversion; OS .50 Nitro; Turnigy Digital Servos (ELE,AIL); Spektrum Digital Servos (THROT,RUDDER); Align 2in1 Regulator and Electronic Glow Plug switched start; Walkera Devo 10 Tx and Rx kit; Fuel Filter; Heli Artist scale Airwolf with retractables.
    NiMhs are ok. Use Sanyo if possible and the ready to use type. They hold their charge for as long as lipos. Buy an ordinary NiMh charger that will charge single batteries. The charge plug is for either a fast charger or a slow charger. Not a power supply.
    Blade 130-X, MSR, MSRX
    Phoenix Sim
      thanks pal but I dont fully understand...
      the charge point is for charging all the NiMh batteries in the pack. The manual specifically states that
        TX chargers come in 2 types, centre pin positive or centre pin negative. Usually I seem to remember Futaba is inner pin +ve, outer is -ve. JR is -ve inner, +ve outer. You need to work out which yours is and buy the corresponding wall charger. Or if you have a charger which has a charging lead for a TX use that making sure you get the polarity correct.
        Neil
        1 x
        Raptor 30, OS32, on its way to being FBL (and leccy?)
        Trex 450 Pro, Beastx, Savox 0257, DS520
        Blade 180CFX
        DX9 & DX7
        Too many planks...
          Retro fitting LiPos into a transmitter designed for NiMhs or NiCads is a BAD IDEA, for many reasons!
          Not least of which is that the voltage alarm is extremely unlikely to work until long after the battery has expired! There was an item about this in the last BMFA mag, and it resulted in the demolition of a large gas turbine model.......
            Positive is inner
            But ive no idea what diameter, charging rate in amps, or volts the wall charger needs to be
            The tx manual says nothing
            Help??
              You put most of that detail in your first post - DC 12V 50mA
                Oh
                Is that what it means
                Rite
                  It will help if you say what you don't understand. NiMh stands for Nickel Metal Hydride. They are rechargeable. The information on your tx is wrong. There are two ways of charging up a NiMh battery. You can either charge it in 1 to 2 hours at a high current or for a long time at a low current. The chargers that often come with a tx are low current chargers that are also called slow chargers. They are used to do an overnight charge. The charge information is on the battery. There are different sizes of battery. The very old 500mah NiCd batteries would be charged at a current in ma equal to teir capacity in mah. Hence 50ma on your tx. The NiMh batteries that you will buy will have much higher capacity. Perhaps 2500mah. These will take around 60 hours to charge at 50ma. If you want to overnight charge you will need a charger that suits the batteries. Or you can look in the Argos catalogue and choose one. These will be fast chargers (mainly) and will stop charging when the battery is full.
                  Phoenix Sim
                    Which information is wrong?
                    The manual is pretty ok , but the english grammar leaves a lot to be desired, but i get most of it.
                    There is no charger with the Tx.
                    What is why i need help. I just very simply need to know what charger to buy (a wall charger that plugs into the Tx) and where can I buy.
                    That's all I need help with - much appreciated.
                      Positive is inner
                      Help??
                      Measure the diameter if you don't know it. Or do what id do in your shoes and Google it. What is the capacity of the batteries you have?
                      Neil
                      1 x
                      Blade 180CFX
                      DX9 & DX7
                      Too many planks...
                        Hi Neil
                        these....
                        4x AA 2300mAh low self-discharge Rechargeable batteries | eBay
                        and there is a charge point on the tx where you plug in a wall charger, but it is the wall charger I need and dont know what to buy.
                        thanks
                          Ok they're good batteries...do you have a battery charger amongst the things you were given? If not then invest in one as you'll need it to charge the receiver battery(s). Then you can get/buy a lead to charge the transmitter from the battery charger at the correct rate (re read cjcj's previous post about rates and mAh etc)
                          Neil
                          1 x
                          Blade 180CFX
                          DX9 & DX7
                          Too many planks...
                            mate, see above.
                              Ok read all the above....if your TX says 12v 50mah only and is centre +ve then go buy a Futaba TX charger.
                              Neil
                              1 x
                              Blade 180CFX
                              DX9 & DX7
                              Too many planks...
