Align power switch led's
  • Align power switch led's
    I have an on/off swich unit (align) with integral glow starter button. On power up The unit has 4 green led's and two that are red. What are they and is it okay to have 2 reds
    Align 600 Nitro Pro 3D; Align FL760 3G FBL conversion; OS .50 Nitro; Turnigy Digital Servos (ELE,AIL); Spektrum Digital Servos (THROT,RUDDER); Align 2in1 Regulator and Electronic Glow Plug switched start; Walkera Devo 10 Tx and Rx kit; Fuel Filter; Heli Artist scale Airwolf with retractables.
    Impressive kit for a novice. Do you have a link for your switch unit?
    Blade 130-X, MSR, MSRX
    Phoenix Sim
      It was given to me after the death of an uncle
      I have no idea what the switch is , never mind a link to it
        Sounds like the standard Align 2-in-1 units, standard equipment on most Align nitro models.
        For the OP, Google 'align 2in1 regulator manual' and you'll find what you are looking for.
          Excellent Mark! Googled it and grabbed the PDF . I Understand it now. Many many thanks!
            http://www.helifleet.com/i/docs/iG/2...gulator_en.pdf
            Phoenix Sim
              We use the same Align regulator as yourself, and stop flying to re-charge the battery once the green lights go out. We have found that this equates to about 50% of the capacity of a 2100 2s LiPo pack.
              The pack will be ready to fly after a 30-45 mins recharge(less if you charge faster).
              Peter
              Member of Milton Keynes model flying club
                thanks guys. Marking this as [SOLVED]
