on my 700LE.???
120' or 140' ccpm
120' or 140' ccpm
Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
- Flickr Through My Pictures.
Tags: None
If when you give fast elevator inputs can you see if the swash moves up or down or just rotates. If it moves up or down then your system has interaction and you could change from what you have to the other and see if that helps. If both setups do it then one or more of your servos or your TX or RX are not playing very well.
I was going to add that is the standard but Jim may have a swash that can do both.Originally posted by tonystevens View Postwell the swash is 120 so id say 120!
Na' just 120 as it turns out, couldn't remember as I haven't flown it since last summer but I've gone through the complete setup again anyway just to be on save side, she just needs test flight for final setrupOriginally posted by Andy from Sandy View PostI was going to add that is the standard but Jim may have a swash that can do both.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
