TRex 700 Blade Grip Bearings
  • TRex 700 Blade Grip Bearings
    Is it necessary to use bearing retainer on 700 blade grip bearings? They look like they'll be quite a tight fit so I'm thinking it's probably not needed and if I do use it it will be very difficult to remove the bearings at a later date.
    Thoughts?
    I've never used retainer on any blade grip bearings
      On second look, the bearing fit is not as tight as I thought so I reckon I'll throw a bit of retainer on there.
      EDIT: JamieM, I Was typing at the same time as your reply! Maybe I won't bother with the retainer. lol
