3GX Went wrong ???
  • 3GX Went wrong ???
    Just set up my 3GX had several flights, Then this time lost contact went full revs.
    All lights on 3GX were flashing radio & 3GX no connection at all. it had been bound 3 time at low throttle.
    Is this the nome with 3GX.
    flyingjacko
    there is a software update that i believe solved that problem, so check what version you have
    James
    Sponsored by
    Align-Trex.co.uk
    Optifuel/optipower
    MKS servotech
      I have updated to V2, Before flying.
      flyingjacko
        Hey.
        I could do with some more details about the model please, such as type, esc, BEC used etc?
        If the spektrum satellite lights were flashing it's telling us the radio link failed and a classic cause of this is through a brownout as the radio gear input voltage dropped too low and the system reboot. This is why I need to know the above model details to try and help pinpoint a possibly cause better.
        Also it may help knowing what the model was doing just before the problem.
        The 3GX is pretty solid, there has been a handful of actual unit failures, but the majority of problems have been through the BEC power supply being not up to the job of supplying power and the radio link then fails.
        Ian Contessa
        Coolice Power Supplies
          Hey.
          You rebound after the V2 setup? Also what method of binding did you use, last position hold or user set failsafe positions?
          Ian Contessa
            Hi Ian.,
            Had v2 From the beginning of the set ups, & its a nitro 600 with OS55,Full battery.
              what type of battery ? are you useing a regulator if so what type ?
              Trex700E sold
              Dragons450 gy401 s9257
              Mcpx
              JRDSX9MK2
              coolice Power Supply
                Lipo + Align Regulator
                  hi the regulator maybe your problem ? ist border line as regards amps for running a flybarless unit and can brown out.
                  Trex700E sold
                  Mcpx
                  JRDSX9MK2
                    Well spotted RED3, What Regulator would you Advise
                      Although pondering on what i was doing at the time i think may of coused the problem.
                      On starting piked up heli left hand radio right hand, 2.4 mast pointing away from heil, i think this is the brown out. But what bothers me is why it went full revs ??
                        Did you setup the gov on 3GX as that's the only poss cause, 3GX cannot cause the revving if gov is not used
                        • Flickr Through My Pictures.
                          The gov is set in the DX8
                            Well if the sat lights flashing then gov in tx could be the fault if signals lost
                              Cant remember what the sats were doing, or if i Nottst, But all the green 3GX lights were flashing
