Originally posted by George J
View Post
Yeah they are a nice layout the Maj frames, with lower maintenance perhaps compared to adding additional gears. But the C/G will move slightly as the fuel tank empties from full to empty, as it's not directly under the mainshaft. So your LiPo Rx pack positioning will be made on a compromise between a full and empty tank, usually when the tanks half full so the change in flight from tail to nose heavy is minimised.
It'll be a minimal change of course, but there still. The old 700N's suffer the same.
Hence Aligns thinking here by moving the engine forward with the additional drive gears, to put the tank directly under the mainshaft. Thus as that weight changes with the fuel being burned, the models C/G stays neutral.
If width wasn't an issue a main gear diameter change over additional gears could have been used, but then that adds width that a slim heli doesn't want :-)
Ian Contessa
