Trex 700n fl head question
  • Trex 700n fl head question
    Having just discovered my blade grip arms are bent on my 700n pro (not dfc) I have looked around and see there is a redesigned head available that has 2 piece grips and arms. Does anyone know if I can just replace my grips with the new design and leave the rest of the head as it is or do I have to change everything please.
    Thanks in advance
    Ian
    Sent from my GT-I9505 using Tapatalk
    Yes mate you can I have done it on mine ;-)
      Thank you for the reply. Just to confirm the geometry of the head remains the same with the links from the swash plate staying in line with the main shaft.
      Thanks again
      Ian
        Yes mate plug and and play but I will doublcheck when I get in if u like
          Hi
          If you could that would be greatly appreciated.
          Ian
            yeah they are exactly the same geometry
              Excellent news Thank you very much for your assistance. Going to order them now.
