I had a blade strike recently, in a low hover tail caught the long grass, damaged main and tail blades, boom, stripped various gears and tail servo gear etc. All repaired now but hit an issue when setting up again with the spartan vortex. Levelled swash with the servo trim menu and got to the collective 0 deg pitch sub menu to set zero pitch for the blades. I can set the blades to zero on one side of the model, but when I go round to the other side to check, I have a 2 deg difference. I have just checked the mainshaft and I think it is very slightly bent, feather shaft seems sound. Tried moving head block throuh 180 on the shaft but no better.
Any ideas until I get a new shaft next week?
