Trex 700 DFC starter shaft
  • Trex 700 DFC starter shaft
    Hi,
    The grub screws are buggered on mine and so the head slips rather than spin the engine.
    I've tried to drill out one if the grub screws that had rounded off, but I've only made things worse.
    These two grubs screws do seem to be a tad optomisitic to be expected to hold the head in place while turning over quite a chunky engine.
    From what I've read some people have had no problems, others a lot of trouble.
    So, is there any third party shafts about which are better designed - ie, something with a hole all the way through and has a bolt would be nice :-)
    Also, is there a way of removing said shaft and the clutch bell without dissasembeling the entire model - on my 600 its easy as you can get to it from the top just be removing the the gryo tray and loosening a few of the side screws....5 minute job. On the 700 the frame is narrower than the bell so it seems that the engine has to come out first.
    Thanks,
    Matthew
    Matthew
    JR X3810 + Spectrum Module
    Trex 600 LE, Trex 500 ESP, Trex 450 Sport,Blade MSR
    DX6i
    Trex 450 Sport (I've two of them so I can fly twice a day)
    My 700le was exactly the same when I had it. Replaced the shaft and coupling and dremmel'd a flat spot on the new shaft to give the grub some bite. From memory, it was a PITA cause I couldn't see any easy way without removing the motor.
    SAB Goblin 700 Beastx
    Align T Rex 700e Beastx
    Mikado Logo 550sx Beastx
    Futaba 8fg.. oooohh
      Sorry but engine HAS to come out first on the DFC.
      Avant mostro 700E
      Avant mostro 700 Nitro
      member of :
      South cheshire heliaddicts
        I don't know what the previous 700 were like - my 700dfc has a smaller frame that my 600le.
        Making it narrow seems to be something of fashion statement rather than have any practical use. These things fly due to shear power not because they are aerodynamic. Better to make them a bit chubbier and easier to work on.
        Matthew
        DX6i
          Don't know about the DFC but on my 700LE, I have been able to remove the clutch block from the top without taking the engine out. Is definitely tricky to do though.
          RE: the frame width, I think theoretically a narrower frame is stiffer.
            And lighter.
            Avant mostro 700E
            member of :
              I can only comment on the 700N v1, but I agree that the start shaft design is a bit poor. I too used a dremmel or similar tool to make a flat spot on the shaft upon which the grub screws can get a good grip. Once that was done the problem went away completely, so happy days. Sounds like you may need a new start shaft kit now, though.
                A drop of red/green locktite and do them up effin tight. Never needed to put a flat on but make sure the grubscrews are new and have a decent point on them
                  Ive not had this problem but some down the field have.
                  Flattspotting the dents makes life easier fixing on and removal because they dont flare and catch the cup when ya replace bearing s
                    This^^^
                    I've only ever had a problem with one hex cup spinning, and it was on a 700n which I bought second hand. I've never had a problem with the ones I've assembled with red loctite.
