0 degrees pitch on new 600n dfc
    I don't think your 6degrees should be purple on mine it's red just a fraction off blue, on mine at center stick I got pitch to nearly zero then levelled swash in beastx menu.
    Regards
    Simon
      @Goshawk
      Which Servo horns are you using? Is everything else stock on yours?
      I was using the Blue ones that came with the kit on the inner hole. Have now switched to the 3rd hole in on the 6 arm plastic ones but still on red at 6deg I don't get blue until about 7deg (which is better than it was but still not ideal)
      I can go another hole in on the arm but I'm a bit worried that will mess up the travel of the rest of the geometry
