After several unknown reason crashes, I have been doing a LOT of research. Especially on Helifreak. I may have come up with some ideas about 2 or 3 of my crashes and the reason for loss of power when flying.
The easiest one is the power loss. When the ESC reaches 80C it engages the battery protection circuit and reduces the power.
Fix? Try and fit the ESC somewhere cooler. Perhaps the North Pole?
Seemingly the full Negative Pitch power into the ground is a common fault. Having read through the Manual, it says that when you BIND the Rx to the Tx you are programming the Rx with the failsafe defaults.
SO, the Rx loses signal and goes into failsafe.
What settings do the average people have? I would think throttle in the low position, Otherwise it goes into vibrate/BUZZ mode doesn't it?
FIX? The only logical fix would be to chuck the DX8 as far as you can throw it?
Or perhaps set the throttle to zero and pitch to zero in the Tx before binding? Any thoughts?
x 3
E.G.S.
