If anyone running a 600E pro wants to speed the tail up or change motor pinion/actual motor,the confirmed info is here for the tail rotor speedup using new Align parts. In a nutshell its the 600N or 550E front TT gearset and the new auto hub for those with an 'A' after the part No.
Changing 600Pro Tail Gear Ratio - HeliFreak
And the KDE motor mount.
KDE Direct - TREX 600E PRO Series Universal Motor Mount and Pinion Support
With the stock 13t pinion its geared to run 2500 to 2700HS dropping to the 700E 12T helical pinion which this motor mount allows will bring geared HS to 2000 to 2250 as well as lowering the torque and allowing more duration,,,,nice
