Power loss issue
  • Power loss issue
    Had this issue happen a couple of times now, so thought I'd throw it out here to see if anyones encountered the same or got any ideas for a solution.
    I've got a trex 550, castle ice 75, beastx (latest firmware) and optipower 5000mah lipos. Futaba T7C & Futaba receiver.
    Upon start up, rotors coming up to full speed, I've lost all power and it dies. However, if I knock the throttle down to zero and power up again, seems to work fine and no issues.
    Now I don't know if I've touched the throttle before rotors are up to full speed and it's not liked it and bombed the power out, or is it something else.
    Any ideas?
    Eric
    DJI Phantom 1.1.1
    Feiyu-Tech FY-G3
    GoPro 3 Black
    hmm.. In the castle settings, under cutoffs tab, theres a setting for max current cut off.. what's that set to? Are you using gov or throttle curves?
    Matt
    Goblin 500 Sport
    Owner of
    One E.G.S.
      Thx for the reply, seriously I couldn't tell you, I bought it of a club member and it's all been set up for me, as I'm basically a beginner / just getting back into it after a few years layoff, so all electronics stuff is beyond me atm, but sure I could find out from others.
      DJI Phantom 1.1.1
      Feiyu-Tech FY-G3
      GoPro 3 Black
        I would expect it to be an ESC problem with the settings, but as you're starting over into electronics its hard to help you really.
        its only doing it on spool up? never in flight?
        If the blades are already spinning does it work or cut out?
        Matt
        Goblin 500 Sport
        Owner of
        One E.G.S.
          Yes only in spool up, never happened in flight - yet! Blades are are spinning up to set rpm then cuts out
          DJI Phantom 1.1.1
          Feiyu-Tech FY-G3
          GoPro 3 Black
            Power loss issue
            Did Roly give you a castle link for your ESC? I have one, we could check it over.
            SAB
            Trex 500 FBL /
            Beast X
            Futaba 8FG
            Proud Owner of 2 EGS Awards
              Just watched a video tutorial on youtube and took a screen shot, this could be it
Name:	Screen shot 2013-08-15 at 08.40.26.jpg
              DJI Phantom 1.1.1
              Feiyu-Tech FY-G3
              GoPro 3 Black
                No Dani he didn't, think the attachment I posted could be it though
                DJI Phantom 1.1.1
                Feiyu-Tech FY-G3
                GoPro 3 Black
                  Power loss issue
                  I don't think it's that. That is related to fixed wing aircraft really. It's certainly a cut off protection thing by the sounds of it. We need to get the laptop out and take a look.
                  SAB
                  Trex 500 FBL /
                  Beast X
                  Futaba 8FG
                    Yeah so either the battery isn't holding up (unlikely IMO) or the esc needs a look at... Particularly with that cutoff I mentioned.
                    looking at the data logs will tell you what's going on or at least provide some clues.
                    also by "flying" do you mean hovering? With you just coming back to it I'm wondering how hard your pushing it?
                    the other thing is anything coming down hot? If the motor bearings are failing then this will increase the current demand massively. Also is the gear mesh right with some backlash on the gears?
                    Matt
                    Goblin 500 Sport
                    Owner of
                    One E.G.S.
                      Yeah just hovering tail and side on atm, Dani will hopefully get us sorted, could be worth a look at the bearings and gearing, or maybe the setup is wrong in the castle ESC, cheers
                      DJI Phantom 1.1.1
                      Feiyu-Tech FY-G3
                      GoPro 3 Black
                        Try giving it a few seconds running at slow speed. Then spool up slowly. It might be something needs to get loose. Anything unexplained can cause a problem later. If you stick to static hovering low down it will land itself. Sounds like overcurrent though due to extra work needed from the motor. It might be spooling up too quickly, that can be like stalling a motor.
                        Blade 130-X, MSR, MSRX
                        Phoenix Sim
