Thinking of a T-REX 450 need some advice
  • #61
    Originally posted by smcb1 View Post
    Tom I got this set when starting out and the hexdrivers rounded out quite easily although at the time I thought this looked like a great idea.
    so whats the best move here then get the offical Align ones??
    Idealyl im looking for a set thats good and wont melt or degrade when working with the tools.
    • #62
      I got this set
      J Perkins Hex Driver 4 Piece Delux Set (1.5-3.0mm) : Icarus Models, Model Shop
      And I havent had a problem since
      • #63
        Hi Tom,
        I am a new boy too and have just built my TRex 450 Sport V2, I found that the hex keys in the kit did the job OK (for now!) I did buy some ball link pliers and a good set of angled tweezers to help hold bits in place.
        I used money saved to buy extra LiPos!!! Als Hobbies in Milton Keynes had a great deal on these prefitted with DEANs connectors. These are apparently Als own design with a little ridge on the connector to make pulling off a little less stressful on the soldered joints.
        Best of luck with the build I really enjoyed mine and found this forum had some brilliant help when it came to the setup.
        sigpic thank you.
        • #64
          Originally posted by tomcoleman View Post
          i just found this box set ? is that ok for the tools?
          RC Helicopter Tool Kit --- BuzzFlyer UK
          I bought one of those kits when I first started out. They do have what you need driver wise for a 450, and include two 1.5mm hex drivers which is perfect for dealing with the 450 feathering shaft. Honestly though, the quality of them is pretty low, and I found after not much use the hex ends started rounding off.
          It'll get you started but won't last the course.
          Steve
          • #65
            Originally posted by Sheldrake View Post
            Hi Tom,
            thanks guys, i will need a quality tool set as for repairs etc.
            Is that all i need is the Hex driver set? or do i need specail plyiers etc? I would rather buy everything at once, i see Align do a tool set as well for £14
            • #66
              Hex drivers, ball link pliers, pitch gauge, and thread lock are essential. Things like a swash leveller can be cobbled up out of bits of wire etc.
              You may find other tools you need but those are the bear minimum.
              Oh yeah and a ruler for measuring stuff.
              Joe
              Invertix 400
              Vortex 285
              TBS Discovery Endurance
              X4 II
              Schluter Champion Longranger
              G4 E720
              G4 E720 Big AIR edition
              Goblin Urukay super slow
              Goblin 700 KSE Slow
              Goblin 700 KSE Fast
              Srimok Faifa
              Spectra G
              Synergy 766
              http://mangled-rc.com/
              • #67
                Joe
                just need to find decent UK stuff as im confused!
                • #68
                  Fast Lad Performance
                  New Arrivals | Midland Helicopters Ltd
                  Job done...
                  Lynx Heli Team Pilot
                  • #69
                    what bits of kit do i need from there ?
                    sorry for being a noob
                    • #70
                      Just the essentials as listed above will do to start with Tom. The rest of the stuff will just accumulate
                      • #71
                        A good set of hex drivers. The align ones are good and don't break the bank. Just buy a standard pitch gauge nothing fancy it should cost 7 -10 quid at the most. Ball link pliers are a personal preference but the align work well on 450s. I use loctite blue 243 thread lock but any blue thread lock should do it. Don't use red threadlock anywhere in a Heli.
                        Just have a dig through the tool sections on the above sites. Fastlad do some very nice tools.
                        Invertix 400
                        Vortex 285
                        X4 II
                        G4 E720
                        Goblin 700 KSE Slow
                        Goblin 700 KSE Fast
                        Srimok Faifa
                        Spectra G
                        Synergy 766
                        • #72
                          ok cool :-D
                          im popping down to the local hobby shop this weekend so i'll see what other things i can pickup :-D
                          • #73
                            Don't assume anything prebuilt is loctited. Best to take it apart and loctite it yourself. Loctite is the most important thing.
                            Blade 130-X, MSR, MSRX
                            Phoenix Sim
                            • #74
                              ok thanks for the heads up
                              what make/model battery should i be looking at, i know someone posted 11.1V 2250mAh
                              Is there a recommended brand? i see alott with different C ratings.
                              • #75
                                Gens Ace are pretty well respected packs for the money. 3S 30C 2200mAh should see you good:-
                                http://electriflyer.co.uk/gens-ace-3...n=ShopperPress
                                Steve
